Did I buy the wrong oil pump??
I'm pretty sure you can change out the spring inside of pump to make it lower pressure if you wanted. You dont really want high flow on a stock pan as you can run the pan dry because the oil wont drain back as fast as you are pumping it out at high rpms. Or so people say.
