Vertical radiator and LT1 water pump... Nd some help!
Old 03-04-2009, 12:06 PM
InsaneAuto86's Avatar
Default Vertical radiator and LT1 water pump... Nd some help!
Trying to install a vertical mount Griffin univ. radiator. Didnt realize I even had this hose until today!
What does the highlighted hose do and can I cap it off at the water pump?
Old 03-04-2009, 01:34 PM
T/A KID's Avatar
Its the oil cooler, I capped mine off.
Old 03-04-2009, 01:36 PM
ss.slp.ls1's Avatar
It's not necessary. In non-oil cooler option fbodys, that hose is run as you see it in the diagram you posted. In fbody's with oil collers, that lower radiator port runs to the oil cooler and then to the port on the WP.
When I deleted my oil cooler, I just capped off the lower port of the rad and the port on the WP. No problems whatsoever. I have no heater hoses either, so my car cooling system is old school, just the two hoses, upper and lower radiator hoses.
Old 03-04-2009, 02:06 PM
Very nice. My heater hoses are gone too. Heading outside to finish this right now. Thanks guys!!!
Old 03-04-2009, 03:49 PM
Javier97Z28's Avatar
What size do you need to plug 'em? I imagine you pulled the actual tubes and freeze plugged 'em?
I plan to pull my whole hvac system sometime this year.
Old 03-04-2009, 03:56 PM
ss.slp.ls1's Avatar
No, I got ragged on for doing this, but I took thick bypass caps and clamped them on the ports. They have worked thus far with no issues. But if you wanted to be more thorough, you could get the ports on the WP welded.
Old 03-04-2009, 03:57 PM
Hmmm, be careful, I've had bypass caps crack on me over the years.
Quick Reply: Vertical radiator and LT1 water pump... Nd some help!
