Fuel filter/Reg fittings
Old 03-04-2009, 12:29 PM
SSable's Avatar
Default Fuel filter/Reg fittings
Ok peeps. I want to avoid using plastic or used lines here. I'm looking for the 3/8 and 5/16 quick connects and the double flare line to hookup my 99' FFR. Does anyone have any knowledge where I can pickup the set? I see tons of repair kits out there, nothing specific. S&P wants to sell you everything for $180??? that's insane. I'm also looking for 6an or 8an connections on the quick connects.
thanks in advance!
Justin
Old 03-04-2009, 04:58 PM
LS1Diva's Avatar
Try Godman Performance for AN Quick Disconnects. godmanhiperformance.com
Old 03-05-2009, 09:35 AM
Old Geezer's Avatar
JEGS and Summit have them.
Also, a search should show up a goodly amt of info, as this is discussed frequently. [Assuming the search function works]
Old 03-07-2009, 09:25 AM
SSable's Avatar
thank you, I found the info. both are 3/8 tubes for the camaro. other model may be differant.
