Custom made drivers side APS discharge pipe!
Well,After trying everything, includeing lowering and shimming the front swaybar to no avail LOL I just redid the drivers side useing one of those frame clearance exhaust pipes with a straight (lipped )pipe i bought from DR GAS!!and fitted and welded everthing up!,which actually clears my tire now when turned inwards all the way , unlike the rubbing with the APS pipe! I must have got a bum pipe because the drivers pipe actually sat 1'' lower then the passanger side and is what bent my sway bar to begine with. I think because it wasnt hitting both pipes evenly or at the same time because the drivers pipe was lower?? So ,from the pics you can see that its actually above the K member bolt now by alittle. Which means i could run without messen with the sway bar now and actually gained my turning radious abit!She isnt painted yet, but figuire you guys would get the idea! I actually bought 2 of these frame clearance pipes,so if somebodys intrested in buying my extra!Let me know.
http://s243.photobucket.com/albums/f...%20APS%20pipe/
