Everybody with Bilet Streetlites 15x4 fronts come in
I ordered a set of the F-body specific Streetlites with the 15x4 up front with a 2.25 back spacing. I am having to do an excessive amount of grinding on my front calipers and from looking at it I will have to grind a little of the caliper bracket. Do I have the right backspacing? Did anybody have to grind this much?
Check this link out on the streetlites, might want to keep an eye on those.
http://www.turbobuick.com/forums/bra...ml#post2120453
You have the Wrong Offset. its a 15x4 1.625
The above post I just looked at, Seems to me MORE was involved with the wheels. I have sold Over 200 Sets and NEVER had an issue, Nor have Never heard a complaint from any of my Customers. That is either 1 of 2 things that have happend in the past. the Customer Mounts the tires up themself and uses Starting fluid to Seat the bead. ( which can cause over 95 Psi of pressure in the tire ) Or the customer hit a Severe pot hole.
