To change tires from 555R to 555 Extreme or not??
Just wanting some opinions...I currently have the 315 Nitto 555R's on my WS6 and the 275 555RII's on the front and am thinking about switching to the same size but in the 555 extreme. I think I like the look of the tread a lil better and they are slightly wider. My car doesnt see the track and it hardly ever sees outside. I've had my tires for about 1 1/2 years and they may have at most 40-50 miles on them. Do you guys think it is worth a switch or would the 1/2" difference in width not be sufficient enough to tell or would having more tread make them "appear" wider??
Also, would the Extremes have pretty good traction or are the drags and RII's going to be significantly better for cornering, etc?? Thanks!
Yeah thats kinda what I was figuring.....was there much difference in width that you could visually tell or did you have 315's?? I was thinking the Extremes might be a tad easier on the rear?
