hp limits on hp tuners and stock ecu
Just was wondering what the limits of stock ecu with hp tuners. I need to make about 1000hp at the wheels with nitrous and was wondering if I need to switch to my prosystems carb to make that power. your info will be greatly apreciated. thanks Mike Salkowski
with 80 pound injectors you are good to about 1100 Hp, beyond that you need an injector driver to run peak and hold injectors.
but of you are asking if you need to change to carb to fuel a 6-700 Hp motor + nitrous the answer is NO, might i suggest the search function........
