just installed my EFI Livev5
Old 10-17-2003, 11:30 PM
jrp
SN95 Director
jrp's Avatar
Default just installed my EFI Livev5
and finally pulled the codes and ran through the program. good lord thats a lot of info to wade through. this program rules though .
codes were:
p0134
p0140
p0155
p0160
p0300
p0405
and they repeat. also it apears as if im running lean as opposed to rich as i had thought.; 13.8-14.9 through out the rev range. im still going through the loads of data looking over things to try and see if i can pin point things that are wrong.
Old 10-18-2003, 01:45 AM
Fetumpsh's Avatar
Default Re: just installed my EFI Livev5
That value is the 'commanded' AFR from the PCM, it might be a different story at the tailpipe!!. You need to put a WB02 on it to see what it's really running, however, commanded 13.8 at WOT is way too lean indeed.
