has anyone replaced an ignition switch
i am trying to replace my ignition switch on my car not the one that the key goes in but the switch on top of the column under the dash has anyone replaced on and what is the easiest way to get to it and replace it
thanks
thanks
Shoebox has a great writeup for this. I did mine w/o the writeup since I didn't know about it until afterwards. It's not hard, just cumbersome if you do it my way(Leaving the steering column in the car and laying on your side/back in the floorboard while working on it). Shoebox has you take the column out.
Good Luck!
http://shbox.com/ignsw/ign_switch_repl.html
Good Luck!
I followed his procedure as well, and it was a very easy fix. Sounds worst than it actually is. I certainly recommend pulling the whole column out of the car, it's worth the extra effort.
ok thanks maybe ill wait till the summer because its not acting up as much as it used to but thanks about how long did it take for you to replace it
