Need a site to print out good info on cam install please
Old 10-19-2003, 01:43 AM
RJF
RJF's Avatar
Default Need a site to print out good info on cam install please
Ok cams not going in for a while longer.Still got to get oil pump,double timing chain.Im looking for a site with great directions on it I can print out to read up on.Im 19 and Ill have my dad helping so I need good direction please.I will be using 918s and there retainers.Once agian thanks for any links you can give me.
Old 10-19-2003, 01:50 AM
jmX
jmX's Avatar
Default Re: Need a site to print out good info on cam install please
The link you need is in the sig.
Old 10-19-2003, 02:17 AM
RJF
RJF's Avatar
Thank you very much do u think the oil pump needs changed car has 65000 miles on it?
Old 10-19-2003, 03:13 AM
jmX
jmX's Avatar
If you have the stock '98 pump, then I personally would change it to a new OEM pump from GM. They are pretty cheap. Buy a few spare oil pump O-rings too just incase...sometimes those things like to get pinched up in there.
Changing the pump isnt definitly a "HAVE TO" item, but at that milage a new pump and chain are probably good.
Old 10-19-2003, 09:02 AM
LS1TECH Sponsor
foff667's Avatar
why do you recommend a new oem pump compared to ported ls6 pumps and stuff jmx?
thanks
Bill
