How to make your fuel lines how to.......
11Second Club
Are you running stock lines? If so, you should just remove your stock feed and upgrade it while you're at it. You can use a braided stainless steel line which will go whever you want it to. If you cut it, you'll need a flaring tool and various fittings, and then you'll need to be able to bend a new hard line to finish the trip to the front of the car. It's more trouble than it's worth, IMO.
