Home depot catch can
Alright I finnally went out and got one but I went to Harbor Frieght and bought a mini air filter for a compressor.
http://www.harborfreight.com/cpi/cta...emnumber=94346
I have not put it on yet because when I blow through the in side of the filter and plug the outside air comes out of the bottom when I unplug to outside it come out of both. You have to pull the drain on the bottom out for it to seal and no air to come out when you blow in it, so does it seal when its pressurized and if so won't it leak oil when the car is off? Is this right or did I buy the wrong type of filter. Thanks
The drain pin on the bottom is spring loaded. No air should come out unless you are pushing it in. If it does, you have a defective one. The one is use is the Cambell Hausfeld one. Same idea as yours. I use it without the little filter inside and it works great. The filter will become clogged with oil quickly. When it does toss it out and dont replace it.
