Head/Cam Swap List, What am I missing?
Old 03-16-2009, 08:19 PM
Unertl42's Avatar
Default Head/Cam Swap List, What am I missing?
I'm trying to get all of my stuff together, and would like to know what I'm missing. I have:
Vengence VRX3
Patriot LS6 heads w/patriot dual springs and Ti retainers
Head Gaskets
ARP head bolts
Comp 7.4 push rods
LS7 Lifters
LS2 Lifter Trays
Vengeance ported & shimmed LS2 oil pump
LS2 timing chain
TSP cam bolt kit (GM Timing Cover Gasket, GM Timing Cover Seal, GM Water Pump Gaskets & GM Harmonic Balancer Bolt)
Yella Terra 1.7 RR
ARP header studs
Locktite
Fluids
So what am I missing? I was thinking about upgrading the lifters while I'm in there.
Thanks
Old 03-16-2009, 08:22 PM
TheLSgun's Avatar
list looks good, but i would definitely upgrade to ls7 lifters while you got it all torn down.
GL
Old 03-16-2009, 08:31 PM
Adam1982's Avatar
Lifters, lifter trays, Oil pump O ring
Old 03-17-2009, 06:09 AM
Unertl42's Avatar
Yeah, I was also thinking about LS2 lifter trays, I'm pretty sure the new oil pump comes with the o ring
Old 03-18-2009, 08:39 AM
Unertl42's Avatar
since "LS7" lifters are not an upgrade, I was thinking about caddy lifters instead
Old 03-18-2009, 09:20 AM
shiv15's Avatar
About the o-ring not sure if the new ones come with it but its only 5 bucks or so anyways.
