how to lock up a TCC manually
Old 03-22-2009, 03:03 PM
rumblebox's Avatar
Default how to lock up a TCC manually
this is an idea i've been pondering for a while now.
first i'm wondering if the TCC is engaged with an on/off type current or variable voltage for firmness....and the actual voltage max.
if it's variable, i would use a potentiometer with a push/pull on/off switch to control the firmness of the lockup.
the reason i want to do this is i'm getting a 4000 stall and want to retain a little bit of in-town fuel economy.
"what are your thoughts, hobson?"
Old 03-22-2009, 04:26 PM
LS1Tech Sponsor
performabuilt's Avatar
You would need to ground the tan wire with the black stripe and unless a kit like TRANSGO or some other kit has been installed you would need to ground the PWM solenoid(not a good idea on the PWM since its designed to be pulsed off and on rapidly)
You would also have to remove test for TCC electrical and PWM electrical from tuning.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-22-2009, 04:28 PM
rumblebox's Avatar
i still want it to come on at it's programmed time. i just want to have a manual override to make it come on whenever i want. do i still have to mess with the tuning?
