air problems
Old 03-22-2009, 03:17 PM
z28pitbull's Avatar
Default air problems
my fuse for air pump keeps blowing, does that mean pumps bad? 2nd if so would that cause fans to come on?3rd can i just unplug the wires from pump and replace fuse?
Old 03-22-2009, 04:33 PM
shbox's Avatar
Normally, yes.
Yes, because there is a trouble code.
Yes, a good fuse and relay with the air pump electrical connector disconnected will normally be ok (if you have a 93-95). It may still cause a trouble code if 96-97.
Old 03-22-2009, 04:40 PM
z28pitbull's Avatar
the relay under hood fuse box? its 95 z if that helps
Old 03-22-2009, 07:00 PM
RamAir95TA's Avatar
Yep. Just look at the fuse diagram in the fuse box.
Old 03-22-2009, 07:03 PM
z28pitbull's Avatar
yep disconnected air pump new fuse, finally damn fans stay off, no service light thank to all that helped
