Gauge Cluster Question
My oil pressure guage in my cluster hangs all the way over to the right and hasnt worked for a while. I was thinking in just getting another cluster. Will a 02 trans am cluster work in a 99 camaro? Was just curious about it before I got another camaro cluster or a t/a cluster.
I have heard both ways that it could be the cluster or the oil pressure sensor. I check the sensor this morning and everything seemed to be fine(not broken off or wires cut). I only felt one wire coming out from it is that how many its supposed to be?
I haven't had that sensor unplugged in a while. If you can wait a month mine will be off again so I will know.
Anyway I would do the following:
- unplug the connector, start the engine & check the gauge
- ground the connector & check the gauge
That should show you if the gauge is working. It should sweep all the way to the left & right depending on open/closed circuit.
I hear you on the part, those are expensive. If you know anyone with a good scan tool you can read the oil pressure while the motor is running. I have efilive (scan only) which can do it and the more expensive hand held OBDII scanners can also display things like this.
So if the oil pressure looks good with the scan tool then I guess the problem is your gauge cluster. If the scan tool can't read it then it's wiring/sensor.
