drive on untuned?
Old 03-23-2009, 10:48 PM
King Nothing's Avatar
Default drive on untuned?
i'm throwing on a set of 241 heads on my 2000 and pulling off the 853's, how much of a difference if any will there be as far as running wise? i need to drive the car 70 miles to get it tuned at the shop and was curious if i can drive it safely without mashing on it or should i just have i towed? tuners can you help me out with some advice please??? thank you
Old 03-23-2009, 11:18 PM
tording99Z28's Avatar
You are only puting the 241 heads on and not a cam at the same time? If only doing the heads then there should not be that much of a difference in the way it runs, I don't see a problem with you driving it to get it tuned. If you are however doing a cam at the same time then you might have some issues.
Old 03-24-2009, 06:13 AM
the cam i'm goin to do is the tr230/224 cam but i'm savin for a new tranny since mine has 146K on it
Old 03-25-2009, 08:42 AM
LS1Tech Sponsor
Rob@EFIAlchemy's Avatar
youll be fine change with just swaping to a diffrent stock head will be very minimal
Old 03-25-2009, 10:05 AM
ok sweet thanks!
