Can I run 39lbs Cobra injectors?
Old 03-24-2009, 08:56 AM
FourG63 97GST's Avatar
Default Can I run 39lbs Cobra injectors?
I know I can run 42 green tops
but I found some 39lb injectors from an 03 cobra (the blue tops)
an wondering if they'll fit in my C5Z the same?
I know nothing about the different brands of injectors and there application, so I'm wondering.
thanx
Old 03-24-2009, 10:24 PM
ACG
ACG's Avatar
You will need 8 Fuel Injector Adaptor Harnesses(square Bosch EV1 style to a Bosch EV6 style). My friend has them on his car, I just don't remember where he bought them from.
Old 03-24-2009, 10:29 PM
TORCHD 02 TA's Avatar
if the injectors are from like 89-04 GTs then go for it. If it is from an 03-04 Cobra SOL...
Old 03-25-2009, 08:13 AM
vsocks1's Avatar
You can get them at buyfordracing dot com!
Old 03-25-2009, 01:49 PM
thats alot, I did run into that different connector issue with the EV6 injector with a EV1 connector. but the adapters are fairly cheap.
Quick Reply: Can I run 39lbs Cobra injectors?
