Nitrous "will this work???"
What is the ETC slot in the Ignition FRC2 fuse panel? is it tap-able??? I have the yellow#86 wire tapped into that slot in this diagram.
Will switching on the ground on a relay set up work? I'm installing a 100 dry shot. This would be a cleaner install for me if it works. I'm tyeing the nitrous and line lock together next to the brake lines.
PS... 99 Trans Am... convertable
