Vette LS2 + 150shot ?'s
Iv got an 05 Vette that I just installed a wet kit on. I am running the stock injectors and fuel pump. Am I going to need to upgrade the fuel pump or injectors for a wet shot? The car runs about 80% duty cycle on motor right now.
Thanks,
Anthony
Thanks,
Anthony
No on the injectors for a wet kit, unless your N/A requirements need them. What other mods are done to the car? Are you seeing any pressure drops on the system now? Generally the stock pump will keep up with minor bolt ons and a mild shot.
Nick
Since its a wet system the injectors are fine at the current 80 percent duty cycle. Looking at your mod list a 150 hp shot is probably going to be more than the fuel system can handle. I would suggest using our C-6/ZO6 dedicated fuel system.
http://www.nitrousoutlet.com/catalog...roduct_id=3260
Thanks guys...Im throwing it on the dyno early next week and starting with a 100 shot. I think that will be enough for me for now until I upgrade the fuel system.
