What else would i need?
debating on buying the compucar bottle in a bag kit from a guy on here, it comes with the whole kit, remote bottle opener switch...
ill be adding a blowdown tube, filter, and WOT switch
prob somewhere down the line ill be getting a bottle heater as well
if there anything else i should get? im thinking a 255 fuel pump? i want this to be VERY save, but i was it to stay hidden too so the less stuff i gotta hide the better
if i only got a safety shutoff switch, would i be good to go?
what do i NEED
what do i NEED
The compucar bottle in a bag is designed to be a bare bone system. Since it is a dry system placement of there nozzle will be critical for the mass air meter to read the discharge. This system is designed for quick install and if I remember correctly the solenoid is at the bottle. It can be easily upgraded but buy the time you convert it to more of a standard set up the cost may be more than buying a actual system. It really just depends on your intentions.
I dont know how much the system is consting you or how far you plan on going with the set up but Vengeance has a sale going on a complete setup for only 599.00
May work out to be cheaper in the long run.
Dave
Dave
