Motor Mount/Trans Mount
1 Post
So when I did my stage 2 clutch, I decided to replace the stock trans mount with a poly mount. Does this mean I should change the motor mounts also to poly?
ive heard rumors if you change to poly mounts you might have problems with feeling alot of vibrations in the car. im thinkin about doin the same but what do u guys think the chances of this are?
