Question for the Diablosport guys
I have a 99 ss and just installed pacesetter lts and was wondering how i'd go about sending in my diablosport tune to have the egr, rear 02, and air codes deleted from the tune? and how much does it usually cost? Thanks in advance!
LS1Tech Sponsor
what revision is your predator on?? when it boots up to the main menu, there's a number at the top of the screen, that's the revision number... what is it??
that number will determine how you will have to get the tune files off the predator - which applications you'll need to use...
you'll also need to have the power adapter and serial cable so you can hook up to your PC to be able to download the tunes from the predator to your pc...
let me know..
let me know..
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
it is the newest revision, i've logged data and used your program to check my LTFTs a while back so i've been able to hook it up. I just need to know what all i need to do after i connect it to the pc, and how much it will cost to have this done, thanks for the fast response also!
LS1Tech Sponsor
PM sent...
__________________
LS1Tech Sponsor
you just need codes disabled??? or what are you looking for??
__________________
