need rear main seal help
Old 03-26-2009, 06:40 PM
sscamaro1384's Avatar
Default need rear main seal help
cant find a write up? any special tools needed or special precautions to take. will also be adding stall. Any one got any info on this type of install.
Old 03-27-2009, 11:10 PM
Anyone have any info on this?
Old 03-27-2009, 11:33 PM
thebulgd's Avatar
Dont think you need any special tools. When I did my rear main seal I removed the rear cover, pried the seal out and used the 4" sewer cap to press the new one in place. RTV where the rear cover/oil pan meat and re-install dat **** .
Old 03-28-2009, 08:36 AM
massls1guy's Avatar
I think you will find more info in the transmission rooms. I changed my rear main seal in november. Didn't take off the rear cover, just pried the old one out and gently slid the new one in. Used a flat head screw driver to gently tap it in around the edge. I installed it dry per the recommendation of an engine bulder near me.
