h/c swap
Old 03-26-2009, 09:58 PM
emolineaux's Avatar
Default h/c swap
ok guys im putting a set of 243s on my 98 z to replace the 241s im now looking into doing a cam while i have it torn apart. any ideas not looking to go big just something to give me a little more power over stock and that willwork with my 243s also would i need new pushrods?
Old 03-26-2009, 10:10 PM
elias_799's Avatar
if you are looking for something cheap and streetable i would go with the ls6 cam.
but i would personally go with the ms4 cam. good luck
Old 03-26-2009, 10:14 PM
jrpimp00's Avatar
Tr224, 224R, 228R, not too big , and great power curve
Old 03-26-2009, 11:02 PM
sroach20's Avatar
do you have stock pushrods? if so then yes you need hardened. depending on your cam size and lifters you may need longer ones.
Old 03-27-2009, 07:29 AM
teke184's Avatar
pushrods will depend on the cam, and if you mill the heads.
heads shouldn't NEED any mill work...but its not a bad idea to clean the surface up and boost compression in the process.
the 224r or 228r would be my first choices for what you want
