alt. and crank pulley v.s alt. and underdrive pulley
Old 03-27-2009, 12:14 AM
robsquikz28's Avatar
Question alt. and crank pulley v.s alt. and underdrive pulley
is there any significant gains with running a alternator and a underdrive pulley over the stock crank pulley....has anyone ever dynoed this and found legitimate gains with use of a underdrive pulley...several peeps want to run just the alternator but will you benefit from an underdrive pulley as well????
Old 03-27-2009, 12:23 AM
hitmanws6's Avatar
if you have an LS1, go for it. LT1's dont benefit from them that much and some people screw up their voltage
Old 03-27-2009, 11:24 AM
yea well im just really wondering cuz pretty much every kit i see out there with someone running it just has the alternator and the crank pulley no underdriver pulley so did they never have one or took it off cuz it didnt do anything at all....
Old 03-27-2009, 01:19 PM
sepno77's Avatar
my bro is runing ud crank pulley and it gave him a noticable gain. so for $70 its not to bad
Old 03-27-2009, 02:17 PM
riceburnerZ28's Avatar
I'm only running the crank pulley. I haven't notice any gains but have notice it's harder to steer when at low rpms. Since my battery is in the trunk I haven't tried the alt pulley.
Old 03-27-2009, 03:08 PM
litch2004's Avatar
when you put a smaller crank pully you have to change the alt pully as well. As hitmanws6 stated it will affect your voltage. When you put a smaller crank pully on it turns your alt pully more rotations increasing your voltage. This is why you install the larger alt pully to compensate for the crank pully because it takes longer for the larger puilly to turn keeping your voltage within range. I used to build and install full blown audio systems and we used to install smaller pullys to increase to voltage output.
As far as an increase it is only a few hp but every little bit helps
Quick Reply: alt. and crank pulley v.s alt. and underdrive pulley
