98 corvette 4L60E trans same as 98 camaro?
Old 03-27-2009, 12:35 AM
Z28_Cory's Avatar
Default 98 corvette 4L60E trans same as 98 camaro?
my trans went in my 98 camaro and i was wondering if a 4L60E transmission out of a 98 corvette is the same? and will it work in my 98 camaro?
Old 03-27-2009, 12:39 AM
LS1Tech Sponsor
performabuilt's Avatar
No case is different , input shaft and stator are different. output shaft is different. wont work period
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-27-2009, 12:52 AM
Z28_Cory's Avatar
o that really sucks i dont have very much money money considering im a 20 year old kidd who got laid off and i found an amazing deal on a 98 corvette 4l60e trans, what other 4l60e trans will work or is it only a camaro firebird or trans am 4l60e that will work?
Old 03-27-2009, 02:32 AM
tording99Z28's Avatar
Pretty sure its only going to be Fbody transmissions that will work. Watch the classifieds section, you might be able to pick up a used one from somebody who is upgrading for fairly cheap.
Old 03-27-2009, 09:23 AM
LS1Tech Sponsor
You can use the LSX truck based trans 5.3 and 6.0 by changing the linkage shaft and the tail housing out,
__________________
Call 888-744-6542
Quick Reply: 98 corvette 4L60E trans same as 98 camaro?
