Spring rating doesnt seem right....
the Z06 yellow valve springs are "rated" for .550 lift as everyone knows....
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
i know with A/M springs if its "rated" for .625 you should go higher than .600,
~ whats the biggest cam you've seen with these springs?
~ how many miles were on the setup?
~ did it end terribly?
2002+ LS6 cam
117 LSA
