1st pass with the 408!
all motor, 75 degrees
1.395
6.442
106.62
1.41?
6.444
106.61
not too shabby.
played with the suspension a lil and went the wrong way. killed the tires.
left in high gear one pass. burnout, staged, wasnt thinking.
1.85
7.02
102.97
last pass it spun the tires near the shift and got on the limiter.
6.47 at 106
its got more in it all said and done.
i need to tweek the carb just a hair more, and play with the suspension.
it will go 30's for sure. i was wanting 9's on motor and i think ill get it.
setup is:
408 iron block
11.7 compression
tea ported tfs 235cc heads
247 255 624 624 108ICL pat g cam hyd roller comp LSL lobe
super victor intake
1050cfm aed 4150 carb
ewp
1 3/4 x 3" headers
3" merge y into a 4" bullet muffler
th350
yank 8" 5200
steel driveshaft
9" 4.33 gears, hoosier DR's
1.395
6.442
106.62
1.41?
6.444
106.61
not too shabby.
1.85
7.02
102.97
6.47 at 106
setup is:
408 iron block
11.7 compression
super victor intake
ewp
1 3/4 x 3" headers
th350
yank 8" 5200
steel driveshaft
