LS2 Timing Chain - How Much Slop?
Old 03-29-2009, 08:40 PM
Geezel's Avatar
Default LS2 Timing Chain - How Much Slop?
97 Vette - I'm in the middle of a heads / cam swap. I just installed an LS2 timing set and have a lot of loose chain (1/8" to 1/4" slop on the opposite of the tight side. What are the tollerances on timing chains?
Old 03-29-2009, 09:45 PM
bills98ta's Avatar
Even my double roller has a 1/4" or better... That's OK !
Old 03-30-2009, 01:22 AM
Notmyvette's Avatar
Is it hard to pull off the crank timing sprocket off a LS1? Do you need any tools like a slidehammer and gear puller or can you just pry it off with 2 little prybars or something?
Old 03-30-2009, 01:24 AM
deadhorse66's Avatar
Use a 3 jaw puller, just like you would on any other engine.
Old 03-30-2009, 04:46 AM
vettenuts's Avatar
There is a tool for removal, about $10 on the auction site.
Old 03-30-2009, 07:39 AM
bills98ta's Avatar
I took my three jaw puller and ground off the back side of the jaws to get in behind it.
