axle movement
axle movement
when i stand at the right rear corner of my 02 z28 and push it from side to side it sounds like where the c-clip clips onto the axle is moving too much. if you jack the car up from the rear and push/pull on the rim how much play should there be? i changed the axle seals about 5,000 miles ago. the car has 56,000 on it. thanks.
Normal on this car. If and when you start driving your car around a track, the axle end play will actually push the brake pistons back into the caliper and you'll get a brief "dead pedal" on the brakes....it's pretty scary the first time it happens....then you get used to tapping the pedal first before laying into it.
