Car Clicks Loudly But Won't Turn Over
Old 03-31-2009, 03:24 PM
Predator's Avatar
Question Car Clicks Loudly But Won't Turn Over
Fellas, I switch the ignition on and the car clicks like crazy but starter won't crank, and so the car won't start. I checked for codes and there are none. I also swapped the fan relay with the ignition relay and still no luck. The battery is good and I even tried starting the car with a battery charger hooked up. The battery by itself is about 12.7 volts. What's most likely the problem, solenoid, starter? Thanks.
Old 03-31-2009, 03:40 PM
Predator's Avatar
Also when I switch the ignition off, the gauges go crazy sweeping. Any ideas? Thanks.
Old 03-31-2009, 04:15 PM
NonGoggleGuy's Avatar
If it doesn't start with a jump, the solenoid/starter is bad.
Old 03-31-2009, 04:17 PM
sasquatch's Avatar
Tested the alternator?
If the you think the starter might be the problem have someone turn the ignition on and tap the starter motor with a prybar. If its locked up that might break it loose.
Old 03-31-2009, 04:20 PM
Predator's Avatar
Thanks for the reply, but what about the ignition switch or BCM module?
I started the car earlier today and let it idle for about 30 minutes and shut it down thinking everything was great. A couple hours later I wanted to go for a spin and it wouldn't crank, just clicking. One thing I've thought of is that I recently started using the wheel tilt up and I'm wondering if that compromised the wires to the ignition switch?
Old 03-31-2009, 04:23 PM
Predator's Avatar
Thanks, I really can't imagine the starter because it always worked perfectly, plus I only got 15k miles on the car. I thought that starters acted funky before they gave out, not working perfectly and all of a sudden dying. I don't know.
Old 03-31-2009, 04:29 PM
If the starter teeth get ground, then it will be a slow, drawn-out process you'll be able to track.
However, if the motor or solenoid fails, your problems will be instantaneous and in-your-face. Before you jack up the car though, try jumping it. It might just be a weak battery with not enough umph to turn the motor.
Old 03-31-2009, 05:25 PM
Predator's Avatar
It's not the battery dude, but thanks. Could be solenoid as you said, but I still think it's either the BCM module or ignition switch.
Old 03-31-2009, 05:39 PM
If it was the ignition switch, you most likely wouldn't even get a click out of the solenoid. Like another said earlier, rap on the starter motor/solenoid with a large screwdriver while turning the key. Also check the tightness of the connection on the starter.
I HIGHLY doubt it's the BCM or ignition switch; but I've been wrong before. That's how we learn.
Old 03-31-2009, 05:40 PM
As far as your needles going crazy... ???? might've been a fluke. Does it still do that?
Old 03-31-2009, 05:58 PM
Predator's Avatar
Unhappy
When I switch the ignition off every time the needles sweep.
I need to dig into my Helm's manual and see what I can find. I think the needles reacting like that could mean something. Another possibility is the crank position sensor.
The reason I don't think it's the battery is because I tried starting the car with the charger hooked up, and the battery reads 12.7 volts by itself. However the battery did get run down over the winter but I charged it and it worked fine until today. The only possibility with the battery I can think of is maybe the cranking power is shot but the voltage is good. And yet the battery has been very strong since recharging it until today. I don't know.
Thanks for your help!
Old 03-31-2009, 06:05 PM
Even though the battery reads 12.7V doesn't mean it's good. When I store my car in the winter, I unhook the battery unless I have access to it to start it periodically. Since it's free at AutoZone, and since you haven't had it tested, it's a good idea to do it. And also, since you said you charged it, every charge will decrease the life of the battery. I'd get it checked.
Old 03-31-2009, 06:10 PM
Marc 85Z28's Avatar
Really? You load tested the battery? What was the CCA? A dead/discharged battery can still show 12.6V
You have a lack of current at the starter. It's going to be either a battery, which is most likely, or a bad battery connection or cable.
Old 03-31-2009, 06:14 PM
Yup. Marc said it better.
Old 03-31-2009, 06:28 PM
SparkyJJO's Avatar
Gotta be the battery man, or the connection to it. Mine did the exact same thing when the battery died. Click-click-click-click-click, battery voltage seemed ok, radio and horn was normal. Replaced battery, all fixed for over a year now.
My old battery was 10 years old, original off the assembly line
Old 03-31-2009, 07:09 PM
Predator's Avatar
Thumbs up
Okay dude, thanks, I'll take a serious look at the battery. It's only a few years old, Diehard Gold. I hope you're right. The 12.7 voltage is what threw me. I left the battery in the car over the winter thinking I would drive the car, but the car sat for a few months in a very cold New England winter, plus I don't have any DTCs so you're probably right.
I have a brand new battery in my TBSS. I'll see if I can hook it up to my T/A and see what happens. Thanks for help! And NonGoogleGuy you were probably right all along, thanks again.
Old 03-31-2009, 07:11 PM
Not a problem. Good luck!
Old 03-31-2009, 07:14 PM
Predator's Avatar
Thumbs up
Marc, sorry, I didn't see your post, but I think you're right. No, I didn't load test the battery. What sort of equipment do you need to load test a battery? The more I think about this, it must be the battery because of the situation it was subjected to this winter, plus it was completely discharged when I recharged it. Thanks for help! Appreciate it.
Old 03-31-2009, 07:17 PM
Predator's Avatar
Thumbs up
Thanks, I'll try my TBSS battery tomorrow and let you guys know what happened.
Old 04-11-2009, 09:01 AM
Predator's Avatar
Sorry it took so long to get back to you. I just went to Sears yesterday and bought a Diehard Platinum and all is good in Mudsville again, so the battery was the problem.
Thanks for the help!
Quick Reply: Car Clicks Loudly But Won't Turn Over
