Comp R lifters, do i need new rockers?
Old 10-23-2003, 05:25 AM
Moose's Avatar
Default Comp R lifters, do i need new rockers?
Was wondering if I'm going to have to replace the stock rockers with adjustable one's, or I'm I ok..
Old 10-23-2003, 06:29 AM
Restricted User
2001 Pewter WS6's Avatar
Default Re: Comp R lifters, do i need new rockers?
I switched to Yella Terra with my Comp R's but then again I am running an XE-R Cam. They are not adjustable but more durable.
Old 10-23-2003, 10:08 AM
robertbartsch's Avatar
...stock rockers tend to spill their needle bearings....but lots of folk re-use them...
...R lifters use less pre-load...
Old 10-23-2003, 10:09 AM
Nasty N8's Avatar
No you can do it with nonadjustable rockers. It is just more difficult to get the preload right. You will need to use shims on the rockers and different length pushrods.
NAte
Old 10-23-2003, 10:56 AM
Formerly 4mulaJoe
LS1x2's Avatar
So with all things being equal and the only change is the comp R lifters you would have too much preload? Is that right? You would then need to shim the rockers up until you got it right?
What are you guys using as shims?
Old 10-23-2003, 12:11 PM
silverZ98's Avatar
do a serch on here and you will find alot of info about that
