Texas speed 1.5?
Old 04-01-2009, 07:22 PM
2slow4uss's Avatar
Default Texas speed 1.5?
Did Texas Speed ever offer a PRC "ls6" stage 1.5 head in a 241 casting? If so, does anyone have any flow numbers or specs? I am looking at a used set, but can't seem to dig up any info on them...
Old 04-01-2009, 07:46 PM
FiFdYnUtz's Avatar
ls6 and 241 dont go together, the 01-02 ls1 head is a 241 and an ls6 head is a 243.....check texas speeds website, they should have all the info you would need on the heads assuming they are their 243 stage 1.5 heads
Old 04-01-2009, 08:12 PM
2slow4uss's Avatar
Thats my problem... the heads are in the original box, but I doubt PRC ever did a 241 head and called it an LS6... So did PRC ever offer a 241 as a modded head through TS? ... sounds like the seller is either mis-informed or looking to scam...
Old 04-02-2009, 01:18 AM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
PRC does 241 heads on occasion but it's not listed on the website, and it would be called a 241 casting head, not an LS6...
Old 04-02-2009, 09:51 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We had ported a couple of the 241 heads, they're stock LS1 heads not a LS6 head.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 04-02-2009, 02:28 PM
2slow4uss's Avatar
When you guys did the 241's did you usually upgrade the vavles? Do you know any of the flow numbers off hand? Sorry for all the questions, just have a killer deal on a set and trying to decide if I want go this route versus a cnc'd 5.3 head...
Old 04-02-2009, 02:33 PM
FiFdYnUtz's Avatar
if you found a killer deal, ported 241's will still show you some decent gains, and if they are 243's, DEFINITELY go for them...
