WS.666
04-03-2009, 07:59 PM
About a month ago, I took Nymphadora out of storage and tried to start her up, but I wasn't getting fuel. So I first replaced the fuel filter, still no fuel. Then I replaced the fuel pump with the racetronix pump and hotwire kit at the same time as I installed my 9" rear end. Before I had the rear in (car still on jackstands), I started the car and ran it for about 5 minutes. I then installed the 9" (needed a new u-joint), and dropped it back on the ground.
One day between school and work, I was outside doing some yard work and decided to let the car idle to clean out the crap in the tank. After about 30 minutes of idle time, I went to check if all of the lights were working after 4 months of storage. When I flipped up the headlights, I noticed that both the lowbeams and highbeams were on, and they were all dim. I figured there was something wrong with the connection, so I reaching past the driver's side headlight and fiddled with the headlight connection. It felt wet, so I pulled it appart to check it out. When I pulled the connection, the engine shut off. This surprised me, but I've seen stranger things happen. So, I reconnected the headlights and went to start the car again, but it wouldn't start. It would turn over, but wouldn't fire. Since I now had to go to work, I just left it.
The car then sat for 2 weeks till I had time to install the new u-joint in the DS and get it installed in the car (Wednesday).
Fast forward to today...I went to start the car and it started and ran for about 10-15 seconds before it died. I turned it over again, it fired twice, but didn't start. After that, all it would do would turn over and over, but not fire, till the battery was dead. I might want to mention, that there is no fuel in the lines (checked schrader valve). I replaced the fuel pump relay, and used the battery out of my suburban to try and get it started, but same result, turning over, but no fire.
Is there anything I'm missing, or should be checking? A buddy of mine suggest that run the pump without a relay, is this a good idea?
This is really pissing me off, and is making me leary of taking the car anywhere, because I'm afraid it won't start at school or work and I'll have to get it towed.
