98 pcm
Former Vendor - No longer Vendor
You don't have to but we would highly suggest that you do so. We did a bit of a write up on this a long time ago.
http://www.efialchemy.com/db/02to97pcm/02to97PCM.html
The 99+ is definately a better choice. However, I have not had any issues using a 98 PCM to control my H/C LS6.
98 PCM uses the back-up VE table for AutoVE. The back-up table columns are scaled every 10 KPa MAP. So, you have to fill in the 5 KPa columns on the Main VE table by estimating the value between columns. PE fueling has not been an issue.
