Could this be a broken flexplate?
Old 04-05-2009, 03:01 PM
blackhawk0251's Avatar
Default Could this be a broken flexplate?
http://www.youtube.com/watch?v=wtK_IFA3OVw
I started my car about a week ago and everything sounded completely fine...a couple of days later I went to start it and heard this noise...The car has been sitting for a while since I blew the transmission...2nd, 3rd, and 4th are gone.
Old 04-05-2009, 03:46 PM
beedo's Avatar
Doesnt sound like a flywheel, sounds like a rod that is completed fked up. Check your oil and see if there is any ''Glitter'' in it but I dont think it is a flywheel but hard to tell from a video
Old 04-05-2009, 04:17 PM
LS1Tech Sponsor
performabuilt's Avatar
Could be a badly damaged flex plate but does indeed sound more like and engine.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-05-2009, 06:04 PM
How would I check the flexplate bolts?
Old 04-05-2009, 06:43 PM
beedo's Avatar
the only way that I know is unbolt the converter and push back towards the trans and move the flywheel back and forth. Look up there with a flashlight and look for hairline fractures. CHECK your oil first, it may save you some time looking for a trans problem. Either way good luck
