head giving me problems
Old 04-05-2009, 03:39 PM
old93camaro's Avatar
Default head giving me problems
Where do i start.. went to take off drive side head because i have 3 broken bolts in manifold holes. well went to take off crossover pipe or air bleeder pipe what ever they call it and the F&&king bolt is striped.. now i try and go look for the crossover pipe and cant find it no where can some one please post a link to where to find it..( i need pipe and bolts) pos is it best to just cut the pipe to finish taking the head off... help please
Old 04-05-2009, 06:47 PM
ss.slp.ls1's Avatar
You should be able to get it complete from the dealer with new banjo bolts and washers. Or look for one in a junk yard and get new washers.
Old 04-05-2009, 09:45 PM
RamAir95TA's Avatar
You could do what some people do and cut the tube in the middle between the two heads. Then when you reinstall, add a small piece of tubing with clamps. Would help if you flared the ends of the tubes if you had the means as well to prevent any leaks.
Old 04-06-2009, 10:40 AM
now i did not think of that.. but how much pressure runs threw that line, do you think it will blow off or get to hot and burst
Old 04-06-2009, 11:14 AM
ss.slp.ls1's Avatar
If you use a thick hose and some nice clamps I wouldn't worry about it. But if it were me, I'd get a new tube w/ new banjo bolts and washers.
Old 04-07-2009, 04:36 PM
yea just ordered the air tube from gmdirect and the guy said it comes wit hthe bolts and washer.. will post pics when i get done to show you if i messed it up or not lol
Quick Reply: head giving me problems
