who makes a 4.125" Crank?
Old 10-24-2003, 01:25 PM
T/A Medic's Avatar
Default who makes a 4.125" Crank?
Hoping for a 427ci solid roller Stroker... 6.0L iron, 6.125 Rods ( have those ) and 4.060 Pistons...
Thanks... Jason
Old 10-24-2003, 01:46 PM
LOnSLO's Avatar
Lunati makes one, and I'm fairly sure that you can get one made from Callies.
Old 10-24-2003, 02:46 PM
Chicago Crew UnderBoss's Avatar
I would avoid a 4.125 crank like the plague in a 6 litrer ironblock as i speak from personal experience when i tell you not to exceed a 4.00 stroke on the LQ4 as the geometry of the motor will be WAY off, and will cause problems with oil consumption, with your reluctor wheel and with scuffed pistons. Also, avoid a CALLIES crank like the plague as my reluctor wheel on a 4.125 crank on brand new one broke and caused my motor to stall out in high rpms just like pro street john's reluctor wheel problem. ALso, from what have seen and heard, callies obvioulsy does not have the ls1 motor perfected yet and they need to stick with JOHN FORCE"S MOTOR!
Stay with a lunati 4.00 crank on iron motor and use lunati. Also, if going to 4.060 make SURE you sonic test block as many come up to thin on clyinder wall.
BEST OF LUCK!
Old 10-24-2003, 03:26 PM
T/A Medic's Avatar
Thanks man... looks like it will have to be a 4.0 with 4.030 pistons so i dont have to sonic test ****
Old 10-24-2003, 06:30 PM
NO problem glad to help. I think going only with a 4.030 is the way to go here for 409 classic chevy cubes and know you can spray the **** out of it if you want or do other significant forced induction! Also, with the .030 overbore you will have extra thickness should you ever need to rebuild the motor, etc.
Old 10-25-2003, 01:57 PM
MASS seller approved
Time2Kill's Avatar
What difference does it make if you use a 4.125 crank in an iron block or an aluminum block. The geometry isn't gonna change between the two. There will be just as much stress on everything in the iron block with a 4.125 crank as there would be with an aluminum block with a 4.125 crank.
Old 10-25-2003, 03:24 PM
That's what i thought also but was told differently by my engine builder. He said there was a difference with my 4.060 overbore on my LQ4 block vs a resleeved aluminum one. What that difference is i have no clue as i am not a mechanic!
