Does anybody know how to wire electric cutouts?
Old 04-06-2009, 10:42 PM
1sicss's Avatar
Default Does anybody know how to wire electric cutouts?
I don't know what to wire the two wires from the cutout to.
Old 04-06-2009, 10:56 PM
jsteele90's Avatar
if you go on the manufacturers website im sure they will have a section to download directions it cant be that hard. just wire it to a switch and supply the switch with power
Old 04-07-2009, 01:56 AM
ZTwentyAteU's Avatar
you need a 6 pole toggle switch. You have to wire it to where it reverses the polarity to go from open to close on the cutout, i.e you want one wire to power it for opening cutout, and the other to ground. To close the cutout the wires need to be reversed.
heres a crappy drawing, but you get the idea
Old 04-07-2009, 02:53 PM
GMRL's Avatar
If your talking about the switch itself, you need a dual pole dual throw switch.
If your talking about the power and ground wires, the best spot for the switch is the ashtray. On the TA, I wired the 12v from the TCS wire, and the ground to a screw on the shifter. I dont have one on the camaro so I dont know where to find a switched 12v source, but a couple minutes of searching with a test light would find you a source. Dont forget to put a fuse on it.
Quick Reply: Does anybody know how to wire electric cutouts?
