6.0L pistons?
? about 6.0L pistons.
hey can somebody answer this question for me?! i bought some 6.0L pistons but i think they are for a 6.0L for the LS1 truck version and i have the LS2 version block and want to know can i still use them?
okay i just foud something about my post. What’s the difference between LS1 / LS6 blocks and the new LS2 aluminum block?
• LS2 blocks feature a 4.00" bore, LS1 / LS6 have 3.898"
• Crankshafts, connecting rods, pistons and cylinder heads are interchangeable between
LS2 and LS1 / LS6 engines
• LS2 cylinder heads are made from the same castings as the LS6
• LS2 blocks have the knock sensor on the side of the block compared to LS1 or LS6 block that have it in the lifter valley.
• The cam sensor has been moved to the timing cover (requires use of LS2 cam gear)
• LS2 knock sensors send a different signal type and are not interchangeable with LS1 / LS6
• LS1 computer will control LS2 engine.
