what size fitting for sts stainless oil line
I need to remove the GT67 while getting the car smogged. Stupid new Cali law requires anything attached, even though it's not hooked up, to have a CARB sticker (getting the CARB retrofit kit too). Anyways, to smog it, I just need to drop the turbo (already dropped the piping). I need to plug the oil feed line from the engine and disconnect the oil pump harness. My question is:
what is the fitting size/type where it goes INTO the turbo?
The instructions mention that where it picks up oil from the filter housing is -4 AN but doesn't mention the turbo side of the fitting. Thanks for any help you can give!
Jesse
Jesse
