evap system
evap system
had my car tuned, got rid of the normal 02 sensors, egr, and shift solenoids for my stall, but can i get rid of my evap system its throwin on my check engine please and thanks
If you get rid of the evap system you are going to have to plug the port on the throttle body, and vent the tank. The 98's have the canister in the wheel well behind the driverside tire. The lines go up to the tank also. I did this and now there are some pretty vicious fumes that I smell everyone once and a while with the car sitting under the car port. So just be aware if you keep it in a garage.
yea it's going to be on top of the tank, like stated. i took everything out except the canister and just put some foam off a 4wheeler air filter over the line that runs from the canister. that way the canister takes care of the fumes, but i removed everything that runs under the car and in the engine bay.
