shift lever diameter ??
Old 04-09-2009, 09:18 PM
gbal4's Avatar
Default shift lever diameter ??
Hey guys what size is my shift lever I`m hoping it is between 10-14 mm I would like to install a new shift ****........... thanks for the help!!! ohh yea I have a 02 SS manual
Old 04-10-2009, 12:20 AM
gbal4's Avatar
anybody??
Old 04-10-2009, 07:57 AM
teke184's Avatar
stock thread is 16mm-1.5
i'm assuming that's what you wanted
summit and jegs sell several ***** for the Fbody with that thread pattern
Old 04-10-2009, 08:37 AM
gbal4's Avatar
is there an adapter that I can use the **** I want is only for 10-14 mm levers??
Old 04-10-2009, 09:16 AM
teke184's Avatar
not unless you went custom....and then you'd have an even longer shifter!!
Old 04-10-2009, 12:42 PM
gbal4's Avatar
well it was worth a try but this is what I wanted for the SS
http://www.bmpdesign.com/product-exe...earch_model/27
Old 04-11-2009, 07:16 AM
teke184's Avatar
seriously?? $190 for a shift ****??
i guess if you're willing to spend that, than having a machine shop build a custom shift lever to fit the threads is no problem.
that would be the best option
Quick Reply: shift lever diameter ??
