Having Trouble deciding, N2O throwing me off
So I'm figuring 475-500 fwhp which on the calculator comes out to be right around 42#'s. (That is at 80% duty cycle btw.)
In one of the sticky's it says you don't need a 255 until ~51#'s
My question is, how does nitrous effect these #'s. I had an argument with my friend today about nitrous and extra fuel needed. I look at nitrous as a combustible gas, therefore not needing extra fuel. But then again, it does add more power, and adds more fuel.
So we came to the consensus that it will depend on Wet vs. Dry. In which case I will most likely be running a Wet 100-150. So, should I up the injector size? And run something like a Walboro 255?
Thanks
Thanks
Hmm great info guys. I always nitrous oxide was combustible. Thank god I decided to not go with chemical engineer haha.
I already have 42# on the way. And I guess I will go with the 255 while I'm at it..
And that will be sufficient enough right?
LS1TECH & Trucks Sponsor
There is no reason to suggest that it's safer to up the injector size with a wet shot. The injectors are not related to the nitrous system in a wet kit, only on a dry kit. If you spray wet, you need not worry about the injectors.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
