Fittings needed to tap into fuel rail
I have a nitrous plate kit im ready to install. I have a few quick questions. Where does everybody mount there relays. I want to keep engine bay as clean as possible. Second Q. What fittings will I need to connect fpss, fuel pressure gauge, and fuel selnoid for kit? Also I have a duel window switch. Where does everybody mount thers? I was thinking in glove box. Is there a better place? thanks in advance
I put my window switch in the glovebox.
Hide the relays where you can easily reach them if you ever have a wiring problem.
You will need something like this for a fuel pressure gauge and fuel pressure safety switch.
http://www.harrisspeedworks.com/shop...&cat=38&page=1
this one has 2 1/8NPT ports, call NX to verify that the back side is -4 female
http://store.summitracing.com/partde...part=NEX-15513
I might be wrong but it looks like those fitings are missing a port. Im going to need a total of 4 ports. One to connect to rail, fpss, fuel pressure gauge, and fuel line to noid. Please helpa brother out
The fitting I posted may be missing one port...but, the fuel rail is 4an. That fitting bolts onto the fuel rail and the fuel line bolts to it. The fuel line will go to a fitting on the solenoid.
