does arp make rocker bolts?
Old 04-10-2009, 09:21 PM
99Ws6TransAm's Avatar
Default does arp make rocker bolts?
IM curious about this? Im running stock rockers..and one of my stock rocker bolts stripped out. Whats the part #? Thanks!
Old 04-11-2009, 07:24 AM
vettenuts's Avatar
Did the bolt strip or did the head strip? Head should go first as its aluminum. Edelbrock sells a bolt kit that is shorter, which are ARP bolts. Just get the length and thread pitch, order those bolts from ARP in packages.
Old 04-11-2009, 07:56 AM
KCS
Moderator
KCS's Avatar
You should be able to find something at the hardware store, if you're in a pinch. I think the threads are M8x1.25 and for the rockers, I think 35mm length will do. If the threads in the head are jacked up, you may need to helicoil it, which I don't know if you should do by hand.
Old 04-11-2009, 11:21 AM
Prerun4fun13's Avatar
No ARP does not make rocker bolts for the LS1 unfortunately. I spent sometime on the phone with them not to long ago trying to see if they did and they couldn't even get me something close. They wanted me to send them a rocker bolt and they could make me a custom set but that was gonna cost way to much so i just bought new GM ones.
Old 04-12-2009, 02:17 PM
Black Plague's Avatar
Edelbrock!
