easiest way to turn off STS oil pump?
I'm removing the turbo and plugging the oil feed to the turbo (to get it smogged - long story, I have the older kit and won't have time to install retrofit kit and get CARB sticker). So, I need to shut off the oil pump so it's not running without fluid. Can I just pull the fuse (15 amp?) and that will kill the system or will I have the buzzer alarm going off? Literally the turbo will be off like a day or two at most so whatever is the easiest way to shut it off is needed. Thanks.
