Lingenfelter launch controller
Old 04-11-2009, 06:29 PM
F-BodyGuy98's Avatar
Default Lingenfelter launch controller
hey fellas, i did a search earlier and found a thread that sounded like it would provide some promising answers but so far it hasent...im looking to get the lingenfelter launch controller with timing retard...is it possible to use it with out using the timing retard? thier installation instructions say for boost based apps, connect a GM 3 bar map sensor to the map sensor connector...see im running a MAF. will this be a problem? and for those not using the retard, how much boost are you building? Thanks
Old 04-11-2009, 10:21 PM
Sluggish's Avatar
You can either turn the timing retard off or just not wire it up. It is an awesome unit, I suggest you pick one up.
Quick Reply: Lingenfelter launch controller
