Help me unflood my engine
I just got done with my turbo build and it won't start. The exhaust pops once then I take the plugs out they have fuel all over them. I think the cylinders are full of fuel. Help!
What are you asking for? If you want some tips on how to get it to start, Just take the plugs and clean them on a 6" electric wire wheel and then unplug the coil harnesses and then pull the fuel pump relay out and then crank the engine over a few times with NO plugs in the engine. This will allow all of the gas to exit the cylinders. (make sure your outside or the garage will fumigate you lol) Then hook everything up and put the plugs back in and then try to fire it up. If that doesn't work, You may have to try it a few times. It worked for me when I put in my 42 lb injectors on a stock tune. If you need anymore help PM me. Take it easy man.
James
James
James
James
